Hi,
Is anyone aware if Firbit Ionic can be connected with Stryd? Or are there any plans for future integration?
Thanks,
Dimi
Hello there @Cyberwiz, my apologies for the late response and of course , you can share your suggestion in our Feature Suggestion board. This is the best place to make your voice heard, but keep in mind it will take sometime to be under consideration, nonetheless our product development teams consult regularly to ensure we're delivering on what our users need and want.
Please take a moment to visit and give us your feedback.
Hi there @Cyberwiz, nice to see you are visiting the Fitbit Community! At the moment I haven't hear of a direct integration with Stryd, talking for a dedicated app on the Fitbit Ionic. At the moment Strava is the only dedicated app that works with Fitbit Ionic.
Perhaps an integration with your Fitbit Dashboard could be possible, but Stryd doesn't figure among the officially supported apps. However there are tons of apps that use our Open API to integrate their service with ours. The best way to tell if an app is compatible with Fitbit is to go to the third party site (or app) and poke around their settings to see if you can connect Fitbit. You can also browse their site for information or contact the app owner and ask if they integrate with Fitbit and what are they future plans.
From my end If I got more updates, I will let you know. See you around!
