04-22-2018
20:47
05:14
RobertoME
04-22-2018
20:47
05:14
RobertoME
I got My Fitness Pal and Fitbit to sync with the calories after it hasn't been working since December 2016, and the calories are syncing now but just for "today", and none of the previous days after December '16. Is there a way to fix this? There are full logs in MFP, so there is definitely info to be transferred over. Thanks!
Moderator Edit: Updated Subject For Clarity.
Best Answer04-24-2018 05:06
04-24-2018 05:06
Hello there @Kaleena, nice to have you here in the Fitbit Community. Glad to read you were able to sync your MyFitnessPal with your Fitbit Dashboard.
In this case your information won't sync retroactively, so all your past data from 2016 won't be transferred to your Fitbit Dashboard, only current date and beyond.
Hope this helps.
Best Answer04-16-2019 20:09
04-16-2019 20:09
Roberto - why is there no way to synch or transfer old data over to Fitbit. I have had terrible problems synching data. When I got first got my LG V30, it automatically synched until a software update (not sure whether it was for MFP or my phone). But after that synching data has been a huge problem. Isn't there some way to get that old data over to Fitbit?
08-08-2019 19:49
08-08-2019 19:49
That is a complete non-solution answer. Will there be any efforts to enable previous syncing?
09-18-2019 19:55
09-18-2019 19:55
I agree that we should be able to sync previous.data. I have a long history with MFP!
01-11-2022 02:21
01-11-2022 02:21
Has any thought been put into adding this yet? I've had issues with myfitnesspal becoming desynced and years of data disappeared from my dashboard.
Knowing that fitbits and other trackers notoriously overcount calories i was hoping to use long term data to gauge just how accurate it is, but now I can only go back a couple of months.
