01-02-2020
12:21
14:31
SilviaFitbit
01-02-2020
12:21
14:31
SilviaFitbit
I saw in 2018 that Yes.Fit wasn’t technically compatible with FitBit trackers. Does anyone know of this has changed. I didn’t see them listed in the app as compatible, but just trying to make sure this hasn’t changed, because Yes.Fit says they are compatible with FitBit trackers.
14:34
07:20
01-03-2020
14:34
07:20
@Revlikens Welcome to the Community. Thanks for the research done prior to posting.
There are tons of apps that use our Open API to integrate their service with ours. The best way to tell if an app is compatible with Fitbit is to go to the third-party site (or app) and poke around their settings to see if you can connect Fitbit. You can also browse their site for information or contact the app owner and ask if they integrate with Fitbit. Learn more about it by checking the Third Party App FAQ .
I'll be around if you have any additional questions.
