02-27-2017
12:26
13:01
LanuzaFitbit
02-27-2017
12:26
13:01
LanuzaFitbit
There is a problem with syncing Walgreen's balance rewards with fitbit one. Looks like I have to buy a new one before I can connect. I have one already so not thank you.
A very warm welcome to the Forums @Feistichick! I moved your post to the Third-Party Integrations board as it is better suited for it.
In this case I'd recommend talking directly with Walgreen and determining if there is something they can do to get the connection going.
Let me know how it goes with them.
Best Answer@Feistichick your tracker has nothing to do with the connection between Walgreens and Fitbit.
My suggestion would be to revoke access to Walgreens by following this post at https://community.fitbit.com/t5/Third-Party-Integrations/Fitbit-needs-to-sync-with-MyFitnessPal/m-p/...
Yes this post is about MFP but the instructions are the same for Walgreens, so choose this instead of MFP.
If it still doesn't work then yes you'll need to contact Walgreens, since they are the ones that handle the link. Fitbit just provides the doorway.
