11-03-2014 03:16 - last edited on 12-05-2015 12:09 by AngelaMa
I'm not very tech savvy but I think it would be awesome if you guys could sync Jefit with Fitbit Jefit is the best workout app I have found and I have been using it for years I believe the calories burned would be more accurate because it will even tell you the total weight that you lifted
11-03-2014 07:06
11-03-2014 07:06
Based on the comments in the Jetfit forums, it does not appear that they are interested in integration with other apps. Take a look here for an example. You can always ask them again.
11-03-2014 07:06
09-15-2017 05:43
09-15-2017 05:43
Anyone have any idea of why they are not providing integration with other apps
06-21-2020 23:18
06-21-2020 23:18
They have integrated it with Google fit...
Maybe it would be worth a try...
