I just set up MyFitnessPal to work with my Flex. Before I wasn't logging activities in using the dashboard as it would take my very active minutes away and it seemed it was making things inaccurate.
Should I log activities into MyFitnessPal then? Or should I just not worry about logging it? I know no matter what it isn't going to be perfectly accurate, but I'd like to at least get a close number.
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
Best AnswerSince the Flex is a pedometer at its core, you really only need to log activities that aren't walking/running. If you have them synced, you can do that either in Fitbit or MFP, whichever you're more comfortable with.
