02-13-2017
13:09
05:31
RobertoME
02-13-2017
13:09
05:31
RobertoME
Sorry for the redundant question as I have seen several fitbit calorie adjustment threads, but I just can’t wrap my head around what is happening.
I am set up in MFP as sedentary with a goal of 2 lbs per week of weight loss. This gives me a net calorie goal of 1790 for the day.
Fitbit shows I burned 3281 and has a projection of 4255. I have looked at my fitbit dashboard and verified that the 3281 includes my lunchtime workout. Fitbit calculates it at burning 440 calories but I calculate it closer to 375 (Samsung gear S2, heartrate monitor, elliptical calculation, etc..)
MFP shows I burned 3198 including 375 manually entered from my workout
The difference is 1057 so I understand this is my offset. However under Exercise it shows my 1057 plus the 375 from my workout showing I burned 1432 from exercise and have 2288 remaining calories from my goal of 1790 (eating 934 so far). If I remove the workout from MFP the MFP estimate for calories burned just drops by that amount and the offset goes from 1057 up to about 1400 so I am left with the same total workout calories.
It seems to me since the fitbit calorie estimate already includes the workout and the mfp estimate also includes the workout my calories burned should be 1057 and it should not be adding the 375 on top of that. I cant imagine eating a 2200 calorie dinner.
What am I missing? Can someone please help explain this to me.
Moderator Edit: Updated Subject For Clarity.
Hello @JerryVO, thank you for joining to our Fitbit Community. About the calorie adjustment between MFP and Fitbit is a bit tricky. Although keep in mind when you create a food on Fitbit account your calorie deficit is already included on your calorie allowance.
Perhaps the difference of calories In MFP in comparison with Fitbit is the BMR. For each day your Fitbit account will account you an amount of calories based on your demographic information, being this the rate at which you burn calories as a result of maintaining vital body functions. Your BMR usually accounts for at least half of the calories you burn in a day.
I've seen this offset too about calories, so if you feel this is causing too much confusion, other users recommend to use MFP specifically to log food and Fitbit to log all type of exercise.
To learn more about Food plan in Fitbit as additional note, perhaps the following post might be of your interest.
Let me know if you have more questions, I'll be around.
