04-21-2018 10:06 - edited 04-21-2018 10:07
As stated my MFP account won't disconnect from Fitbit. I am cutting and I don't want MFP constantly increasing my daily caloric intake because of my activity level.
I have searched the forums and tried everything suggested. I disconnected from MFP in the app, I revoked access from the dashboard. I restarted all devices and applications, and everything continues to be connected.
Any help?? Please.
Best Answer04-24-2018 05:43
04-24-2018 05:43
Thanks for the reply. I had to contact MFP and have them disconnect it on their end. Nothing else would work. Seems like a known issue because there’s lots of entries in their forums asking the same question
I knew MFP was still connected because it kept syncing exercise into MFP and adjusted my daily caloric limit. I am cutting so when I go to check my daily remaining calories it was constantly increasing which I don’t want.
04-24-2018 04:43
04-24-2018 04:43
Hi there @lytefall, good to see you again in the Fitbit Community! I was reading you are having troubles to disconnect your Fitbit Dashboard from MyFitnessPal. The best way to tell this is by reviewing your Fitbit.com Dashboard in your Application settings. If you are not able to see MFP there, this is confirmation that doesn't have access to your Fitbit Dashboard.
I'm wondering why you have your concerns that MFP is still connected with your Fitbit account? Have you seen entries coming from MFP?
Let me know if you have additional questions, I'll be around.
04-24-2018 05:43
