06-25-2015
07:08
06:37
06-25-2015
07:08
06:37
@EA828 It's great to have you here! Fitbit will sync distance and calories to MapMyRun. However, MapMyRun data won't sync to Fitbit.
What exactly are you seeing that's not matching?
Keep me posted ![]()
08:56
06:37
06-25-2015
08:56
06:37
@EA828 If you have them linked then both apps should show you the same amount of steps because they are syncing. Just make sure that when you're seeing your steps your Fitbit tracker has synced so you can get the correct number of steps.
To make sure that you're seeing the same steps, do the following: Go to your Dashboard > click on 24/7 tab > below that you'll get steps, sleep, workouts, weight, distance and calories burned.
Let me know how it goes ![]()
10:37
06:37
06-30-2015
10:37
06:37
@EA828 Thanks for the details! If you can provide me with a screenshot, I'll be happy to investigate it.
