Fit bit not adding all activities from My Fitness Pal
Hi , this is the first time I've done multiple exercises on the same day. I log the activities into My fitness pal and when syncing it only adds the first activity to fit bit. How do I add the other activities?
6 REPLIES 6
@SunsetRunner Hey there! All the activities that you log in MyFitnessPal should sync to Fitbit. I would like you to unlink and relink both accounts to see if this resolves the issue and avoid this from happening in the future.
Hope this helps.
Hi thanks for the response, how do you link and unlink the devices?
@SunsetRunner To unlink both apps, do the following: Go to your Dashboard > click on settings > Applications > Click on Revoke Access.
Keep me posted.
Hi Sylvia, I have unlinked the Fit Bit and MFP, how do I re attach them?  Thanks
Hi Silvia
I have un linked my MFP and Fit Bit and re connected them, and the Fit Bit
exercise is still only showing the first item of exercise in the exercise
tab
Thanks Catherine
@SunsetRunner I'm glad that you already linked the accounts again. It's weird that not all the exercised are syncing to Fitbit, please contact MyFitnessPal directly so they can check why it's not transferring.
Hope this helps.
