08-28-2015
06:06
06:03
AngelaMa
08-28-2015
06:06
06:03
AngelaMa
This morning I have walked 7.68 miles/17925 steps according to MMW. My FitBit Charge HR has registered 5.52 miles/12484 steps. I am not worried about the step count as such, because I think that is pretty accurate, but the difference in mileage is not negligeable and it is frustrating. Does anyone have a solution for this please? I am feamale, 5' 6" and my stride length is set to 2 feet 4 inches. I have checked my route on another app and the MMW distance is correct. Is there a difference between stride and step length?
@PinkyWinky Welcome to the Community! Thank you for the details that you've mentioned. The reason why you're getting different readings is because Fitbit trackers will calculate distance based in your stride length and MMW will track it using GPS.
You can learn more about it here.
Hope this helps.
