05-05-2014
09:34
12:20
AngelaMa
05-05-2014
09:34
12:20
AngelaMa
Everything is syncing well but my meals for some reason fit bit is only recognizing one meal a day from my fitness pals food diary. Yesterday it was my snacks today lunch. Any ideas?
I hope you are doing great @JenF! If you are having issues with MFP not syncing the correct food logs, I recommend to unlink and relink both accounts in order to ensure a better performance between them. Please do the following:
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MFP.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
I wish you the best! ![]()
