12-20-2014
08:48
08:02
AngelaMa
12-20-2014
08:48
08:02
AngelaMa
Everything says that my fitness pal and my surge are synced. Yet I always have to sign out and disconnect fitbit and then reconnect in order to show my steps in my fitness pal each day. Very frustrated.
12-22-2014 08:59
12-22-2014 08:59
@Aprinzessin Thanks for reaching out I'll be happy to help you today.
I heard about syncing issues with MyFitnessPal but we cannot confirm it yet. According to your post, you were able to disconnect and reconnect both MFP and your Fitbit account again. Please make sure you're doing the correct process by following the steps below:
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by clicking here.
Let me know if the steps work properly.
P.S. Welcome to the forums!
12-22-2014 11:55
12-22-2014 11:55
12-24-2014 09:55 - edited 12-26-2014 05:04
@Aprinzessin Have you already contacted to MyFitnessPal support? If not, please do so. I will be investigating on my end but I'd like to know if they are also aware of this issue. Thanks!
P.S. Happy Holidays!
12-24-2014 16:38
12-24-2014 16:38
12-25-2014 03:35 - edited 12-25-2014 03:36
Hey @SunsetRunner! I'm so sorry for the inconveniences between MyFitnessPal and Fitbit. Are steps taken only being affected in this case or there is an issue with logged food as well?
Did you try the basic troubleshooting steps to fix this issue (unlinking and relinking both accounts)? If not, please do so by following the steps here.
If you keep experiencing the same issue, please contact to MyFitnessPal Support and let them know about this odd behavior. Keep me informed if you're able to fix this or not. I'll be happy to lend you an extra hand.
12-25-2014 12:05
12-25-2014 12:05
12-26-2014 04:51
12-27-2014 07:07
12-27-2014 07:07
12-28-2014 08:33
12-28-2014 08:33
@Aprinzessin Thank you so much for sharing that information. I'd need to check your Surge functionality and some internal logs to determine what's going on with your syncing behavior, that's for sure!
In the meantime, could you please confirm you've done the steps listed in this article? Make sure your tracker is syncing properly and that's syncing regularly. As soon as your "MFP integration" stays connected with your Fitbit, you should see your steps in the "check-in" section of MFP. With this, we understand you'll need to sync every day if you want to see your steps updated.
Let me know how the steps work.
01-10-2017 07:41
01-10-2017 07:41
I did everything listed in this post to try and get my fitbit and my fitness pal to sync. I get all the information synced from my fitness pal to fitbit but my steps don't show up anymore on my fitness pal. It worked fine before but ever since like December my steps don't register.
01-10-2017 08:54
01-10-2017 08:54
I'm having exactly the same problem. And it happened right around the same time. I thought I saw that my myfitnesspal app updated right around that time. But when I look back at my history, one day it only showed like 20 steps or something (presumably the day this started) and then after that, nothing. I too have tried all the steps listed here and have had no luck.
01-31-2017 13:22
01-31-2017 13:22
01-31-2017 13:26
01-31-2017 13:26
I've managed to get my steps to connect today by disconnecting and re-linking my accounts, but none of my steps since October have been copied across. Really annoying. Is there any way to update these missing steps?
03-07-2017 07:47
03-07-2017 07:47
I've had the same problem since I started using fitbit so no steps have been logged in myfitnesspal. Solved the problem today, on the myfitnesspal app menu, there is a tab for steps. Mine was set on mapmyfitness, not fitbit so I changed that, then disconnected and reconnected the accounts again and finally the steps are showing. Unfortunately doesn't show the steps from the past 3 months but better than nothing I guess:)
03-07-2017 07:56
03-07-2017 07:56
I've been trying this. Every time I re-add fitbit as the steps tracker, I come back to Apps and it says none selected. It doesn't seem to save the fact that I picked the fitbit tracker. Really annoying
03-11-2017 18:28
03-11-2017 18:28
Where is the gear icon?
03-12-2017 09:27
03-12-2017 09:27
Good afternoon,
I have recently added Fitbit HR to MyFitnessPal. (3 days now). My steps are showing up but they are listed under Check-In instead of under exercise. ( Listed are steps, body fat and sleep. ) How do I move steps from this area to the exercise area so they can be counted?
Thanks!
05-24-2017 15:25 - edited 05-24-2017 15:29
Solved problem for me. In the app as suggested go to steps in the menu. It was set to my old Microsoft health link from when I had my Microsoft Band. Even though I had removed the link in the connected apps section. Did a sync and steps and excercise from today in fit bit synced and showed correctly.
Thanks
08-29-2017 06:58
08-29-2017 06:58
I have a charge 2 and I don't see a gear icon either
