I just got my Alta hr today and am trying to connect my Fitbit and MFP. No matter how many times I revoke and try and reconnect, they will not sync. In MFP it says that it is installed and connected, but it doesn’t actually show up on the apps list As “connected”. None of my steps or food/exercise is syncing. Help!
Best AnswerFrom what I understand, your workout info doesn't actually sync up with MFP, but the calories burned/calorie intake adjustments do. As for the steps, I had the same problem. I had another step tracker linked, so I had to disconnect that before it would start tracking my Versa. Go to your settings, then apps & devices, unlink whatever other step tracker you have (could be a phone app such as SHealth if you have a Samsung device), then link your Fitbit. I'll get back with you if I discover anything else, or if I find out I gave you wrong information.
