06-26-2018
05:27
09:16
LanuzaFitbit
06-26-2018
05:27
09:16
LanuzaFitbit
Suddenly Myfitness pal has stopped working with fitbit. Used to work beautifully .Yes, I've disconnected and reconnected, uninstalled and reinstalled the apps. Yes, both apps are up to date. Seems like these are the only suggestions ever given by support I used to be a huge fitbit fan but my support is dwindling with all of the constant sync issues between apps and within the fitbit app itself.
Moderator edit: Clarified subject and Label
Welcome to the Forums @CBender22.
Thanks for sharing everything that you have tried. In this case I'd say that contacting MFP is the best way to go about it. These third-party connections are created by the third parties and as the ones who worked on it, they should be able to check what is going on.
Please get in touch with them and keep me posted on how it goes, or if you have any further questions.
