01-03-2018 13:11
01-03-2018 13:11
Food I enter into fitbit is not syncing. My weight, activity & steps are all syncing, just not food.
12-24-2017 04:31
12-24-2017 04:31
The issue with MyFitnessPal and Fitbit not syncing is back..tried connecting and disconnecting and still an issue!
12-24-2017 04:33
12-24-2017 04:33
Okay, so ive just gotten a new fitbit instead of a garmin and am having difficulty getting them to connect properly. I connected both and it showed up however the step count was zero so i followed the instructions of disconnecting both, logging out, logging back in and reconnecting. Still, they show as connected but no data is transfering between them. Any suggestions?
12-24-2017 06:03
12-24-2017 06:03
This post has a link to help solve this issue.
The best we can advvise is to revoke access. Then reconnect through myfitnesspal.
If this doesn't work, you will need to contact myfitnesspal.
12-28-2017 11:47
12-28-2017 11:47
My Fitbit won’t sync with My Fitness Pal for the last 2 weeks. I have tried revoking access and then reconnecting but still won’t work...any ideas?
12-28-2017 12:51
12-28-2017 12:51
Did you revoke access through Fitbit or MFP?
Try both. Then connect if this doesn't work then contact MFP. Fitbit is not responsible for the connection.
01-01-2018 11:03
01-01-2018 11:03
Worked just fine for several years and now for the past 2 or 3 weeks will not show my steps on fitness pal so I get no extra calories. Have checked setting in both apps and can’t figure out what is wrong. Any ideas?
01-01-2018 11:49
01-01-2018 11:49
Hello @MamaDonna
You can try this to see if it sync's better:
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
01-01-2018
14:47
03:34
01-01-2018
14:47
03:34
I have bought a new fitbit and it's not syncing my steps to my fitness pal.....does anyone know what I should do? Thanks!
01-02-2018 03:36
01-02-2018 03:36
Hey there, it's nice to see a new member around. Welcome @Laineybird77! If your data is not syncing with MFP, I recommend to unlink the accounts and them link them again. Doing this should be able to resolve any issues between the account.
To do that, follow these steps:
1. Sign into your Fitbit dashboard.
2. Go to the Applications settings on your account.
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts.
Let me know if this works guys!
01-02-2018 05:56
01-02-2018 05:56
Hi All, I know I have seen this topic in the forum in the past but I am a new Fitbit Charge 2 owner and I am having no success with linking the My Fitness Pal app to my charge 2. In both places it is saying that the two are linked but they are not sharing information. I have done some of the things that have been discussed in the topics (i.e - uninstalling and reconnecting) but nothing seems to be working.....please help!
01-02-2018 09:21
01-02-2018 09:21
My Fitbit Charge 2 does not sync with My fitness pal. On a previous post you say to go to Fitbit Dashboard and hit apps and revoke fitness pal. I don't see this option on my screen at all, yet in the My Fitness Pal zapp it shows I am connected to Fitbit.
Lynn
01-02-2018 09:49
01-02-2018 09:49
I have the same email address for both apps, have connected them on each of the apps, but my exercise does not sync from my fitbit to MFP. What do I need to do?
01-02-2018 12:21
01-02-2018 12:21
Mine just recently stopped syncing on 12/16. I have uninstalled and reinstalled but still not working
01-02-2018 12:26
01-02-2018 12:26
01-02-2018 12:29
01-02-2018 12:29
Thanks I am going to try
01-03-2018 14:20 - edited 01-03-2018 14:21
I believe it says to only enter your food into MFP and not into Fitbit. It won't sync. My food and calorie intake is syncing but my steps and activities aren't syncing into MFP. The only activities that are syncing are my steps from my iPhone. UGH!
01-04-2018 04:24
01-04-2018 04:24
I am ready to delete MFP because of this same problem.
Fred
01-04-2018 07:38
01-04-2018 07:38
I cannot get my Blaze and MyFitnessPal to communicate!! Have tried everything... Suggestions??
01-04-2018 09:44
01-04-2018 09:44
The Fitbit on my wrist and phone is not syncing with My Fitness Pal = I contacted MFP and went through the steps and it is still not synced when I log food, exercise, or water through MFP
