Hi there @Bobbomcd, good to see you here! Many of the third party integrations are not developed by us and we don't have the control over this data or how it will be interpreted by these services.
In the case of MapMyFitness programs only the following information is going to sync:
| Fitbit > Distance > MapMyFitness apps |
| Fitbit > Calories > MapMyFitness apps |
For more details please take a look at the following posts: Third Party Apps - Informational Post or Third Party Apps - FAQ.
See you until the next time.
Best AnswerWhen I export my workout from the Fitbit website on my computer .. and import on the MapMyRun website on my computer, I get all of the information for my workout.
When I use the app for both providers or a mobile device I get errors and incomplete information.
Garmin wearable trackers can directly sync to MapMyRun... if they can do it I'm sure you would be able to as well. Try working with them and fix the problem.
Hello @Bobbomcd, thank you for your feedback. I was reading you were able to upload the data using the computer. So I believed this is an error in the mobile app, although I'm not sure if I mentioned this before, but we do not own the integration, so we are not able to control this data since is not from our end.
In the post I shared before Third Party Apps - FAQ. there are more details and I quote: "Fitbit doesn't own or maintain third party integrations. It's up to the owner of the third party app to implement or update features for their app. Unless there's some sort of limitation on Fitbit's side (e.g. no Fitbit SDK), then it's safe to assume that the owner of the app is the one to contact if you're interested in seeing the integration improved"
Nonetheless you feedback is very valuable for us so I will share this information with my teammates.
See you around.
