02-08-2022 06:48
02-08-2022 06:48
Using my Charge 4, I have 4 Activity Shortcuts that I typically use: Bike, Hike, Walk, Outdoor Workout (OW) The first three sync nicely with Strava, including GPS data, using phone GPS always.
I use Outdoor Workout (OW) for my mountain bike trail building activities, using phone GPS as with the other 3 activities. The OW is seen on Fitbit nicely, with GPS data. However, the OW is never synced with Strava, even with GPS being used.
How can I get Outdoor Workout, with phone GPS data, to be synced with Strava?
Or, is there a way to manually send the OW activities to Strava?
Thanks!
02-08-2022 10:57
02-08-2022 10:57
Try if you can export TCX file from Dashboard after you're done with recording Outdoor Workout. If you can and it's not (almost) empty then you can manually upload it to Strava. Otherwise, there is nothing you can do. I haven't used OW so not sure what data looks like.
Best Answer02-08-2022 10:57
02-08-2022 10:57
Best Answer02-10-2022 05:21
02-10-2022 05:21
@TNSteve Outdoor Workout is designed for things like kayaking, stand up paddle board and downhill skiing. If I were you, I would use Bike, a much better fit.
Laurie | Maryland
Best Answer02-11-2022 06:59
02-11-2022 06:59
Best Answer02-11-2022 14:03
02-11-2022 14:03
Have you tried using the OW with your fitbit GPS (not the phone GPS) as an experiment?
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
Best Answer02-12-2022 08:06
02-12-2022 08:06
