Hi, would appreciate some advice on this since Peloton support have been next to useless......
I used to have a Peloton tread and I enabled the Peloton to Fitbit integration. All was fine - every activity that I completed on the tread also went across to be displayed in Fitbit. Any activity I completed in the Peloton Android app also went across to Fitbit. All good!
However, I got rid of my tread and just now use the Peloton Android app. I foolishly deleted the Peloton to Fitbit integration at the beginning of the year to see what HealthConnect integration is like. However, I didn't like the HealthConnect integration as it gives you far less information. So I renabled the native Peloton to Fitbit integration in the Peloton Android app. Since doing this, no activities have been sent to the Fitbit app. I'm wondering whether this is a problem or whether it was because I originally enabled this functionality on the Peloton Tread and the Peloton App just doesn't have this function.
Can anybody check/confirm/deny this for me?
