10-02-2020
02:32
08:33
AlejandraFitbit
10-02-2020
02:32
08:33
AlejandraFitbit
I have connected runkeeper to my charge 4, but after my run activity it will not sync to runkeeper. When I go to runkeeper under "Apps, Services and devices" it says "Fitbit connected". What am I doing wrong?
I tried to connect for the first time yesterday. I did find a way to work around the issue. It works if I disconnect FitBit in Runkeeper under Apps, services and devices and then connect again. Maybe that is the only solution, but a bit strange....
10-04-2020
08:35
07:56
10-04-2020
08:35
07:56
Welcome to the Community, @lottasunden and @SunsetRunner, thanks for the input.
I just wanted to let you know that I have moved your post from the Charge 4 board to the Third-Party Integrations board, since I think that here you will be able to see more related topics about RunKeeper.
Now about your issue, thanks for troubleshooting it. It's great to hear that it is now working properly. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up!
Best AnswerI've experienced this as well. It seems that your runs won't go from Fitbit to RunKeeper automatically. The only way to get it to work is to disconnect and reconnect every time.
Exactly! I do the same - disconnect and connect every time.
I doesn't work well.
It stops syncing the activities to Runkeeper. So I have to disconnect and reconnect Fitbit and Runkeeper every few days to push the activities to runkeeper. It works okay for Strava though.
Can you please confirm this is not a Fitbit issue, so I can bug Runkeeper folks?
