05-12-2024 07:12
05-12-2024 07:12
I am questioning if my Runkeeper integration works as intended:
Currently, after I have connected the two apps via the Runkeeper app, Runkeeper successfully imports data from Fitbit, but Fitbit does not import data recorded through Runkeeper. Is this working as intended? If yes, is there any way that I can import my from Runkeeper without doing it manually (it creates a duplicate in Runkeeper as it imports it from Fitbit...)
Best Answer05-20-2024 08:40
05-20-2024 08:40
Hi @kdfkldsfank you will need to ask runkeeper this. However, in general you would want to only use one app to record your workouts.
