02-21-2024
17:59
16:03
LizzyFitbit
02-21-2024
17:59
16:03
LizzyFitbit
I have been hoping natural cycles would integrate with fitbit for a few years now, and now that they are compatible with the oura ring and the apple watch, i’m wondering if they will ever merge with fitbit. This would be so so useful. Just wondering if it is in the works?
Moderator Edit: Clarified subject and updated label
Best Answer03-13-2024 16:12
03-13-2024 16:12
Hi there, @karllii.
Thank you for sharing your feedback with us. I understand how helpful it would be to have the data tracked on both apps synced together.
I'd like to explain to you that our web API is open for other services to integrate with Fitbit. I suggest sharing this idea with Natural Cycles and directing them to our API, SDK, and resources, such as the web dev API community. They can use these resources to make the integration happen. You will likely be able to email them via their contact us page or customer support, or encourage them to reach out to Fitbit directly.
03-25-2024 19:25
03-25-2024 19:25
Does this mean that Natural Cycles simply needs to setup an integration with Fitbit, rather than the two companies setting up a professional partnership?
03-28-2024 11:18
03-28-2024 11:18
Welcome to the community forums, @coleycoleyy.
Thank you for joining this thread. Fitbit's web API is open, allowing any company or developer to integrate with Fitbit.
I understand your concern and while you can share this idea on the Product Feedback board to get the attention of our development team, I still encourage you to share it with Natural Cycles so they can use our web API to integrate with the Fitbit app.
04-23-2024 16:45
04-23-2024 16:45
Yes that's what they mean. Submit a request to Natural cycles. Fitbit doesn't have to be in a partnership. They have an open API.
04-24-2024 10:08
04-24-2024 10:08
Hi Karlii,
Have you been able to reach Natural Cycles and ask them to integrate with Fitbit? It looks like Fitbit is open to the idea. I can't reach Natural Cycles via their chat support function -- it's quite limiting in nature.
04-29-2024 15:15
04-29-2024 15:15
@coleycoleyy It's good to see you here. @GlassHalfAsleep Thanks for your help!
@coleycoleyy and our friend mentioned, our best advice is to get in touch with them so this integration can be possible. I took the liberty and found their Customer Support web-page, which can be found here. You can also check if they have their own ideas board like the Product Feedback board where you can submit your idea.
Best Answer04-30-2024 05:50
04-30-2024 05:50
Natural Cycles unfortunately does not have Product Feedback board (from what I can tell) and I am unable to submit feedback via their Chat Support function via the Customer Support page because their chat bot selections are limited to pre-existing product offerings. Bummed but thank you for your help!
05-05-2024 13:26
05-05-2024 13:26
Hi there, @coleycoleyy.
You're welcome, thanks to you for visiting the Product Feedback board. To submit your idea, just click here and provide as many details as you can so our developers can understand your request, and categorize it accordingly. If you want to know more about this board, check our FAQs.
Best Answer05-20-2024 08:49
05-20-2024 08:49
With the Chat support, I'd choose App. Then put in my request. Since the AI won't be able to help, the chat will be forwarded to a human
