I have Fitbit connected to both MyFitnessPal and Runkeeper. Since I started using Fitbit to track all my activity, I really only use Runkeeper to track my weight, since I have years and years of that data there. Currently, I have a Renpho scale that sends the weight data to Fitbit. Up until recently, Fitbit then pushed that data to Runkeeper. Although I didn't monitor other things as closely, it looks like Fitbit also passed a lot of additional data like running activities, steps taken, calories consumed, and sleep quality.
Since some time last week, a lot of this data stopped being passed over. Now the only items that are passed over to Runkeeper is when I complete a run. While Fitbit still gets the readings from Renpho, I have to manually move weight data over to Runkeeper from there. Disconnecting and reconnecting Runkeeper access to Fitbit does not fix this.
Although I can't be certain of this, it seemed like integrating weight data stopped working at about the same time that I started experiencing the same MyFitnessPal calorie adjustment issues that other people have mentioned here. Is it possible that this is related? If so, I'd just like to make sure that this gets looked at as part of that.
I see that the issue with syncing third-party apps has been listed as resolved. I am still seeing issues with syncing with Runkeeper, though. Particularly the weight data. I have disconnected and re-connected both Runkeeper and Renpho to Fitbit. Is there something else that needs to be done to make this connectivity sync again?
