So I read that you can sync Fitbit with Runkeeper. I have a Charge HR and looked on Runkeeper.com to connect my Fitbit.
https://runkeeper.com/apps
Where is it? It is not in the list, and when you search for "Fitbit", you only get "Fitbit Zip".
09:29
05:08
09-18-2016
09:29
05:08
@witter56 Welcome to the Fitbit Community! It is possible to connect your Fitbit with Runkeeper. To link them do the following:
Keep in mind that this is a one-way integration, meaning your Fitbit data syncs to Runkeeper but not vice versa. If you run or jog without your Fitbit tracker on, it will not be automatically recorded on your Fitbit profile. If you prefer to use RunKeeper over a Fitbit tracker, you can manually log your RunKeeper stats on the Log section of your Fitbit account.
Hope this helps. Let me know how it goes! ![]()
