After some advice guys, just bought a Blaze and am unsure how this is supposed to work. Basically, I went for a walk, it synced over the steps to MFP but 0 calories burned which is a bit useless
Should it not show how many calories I burned?
Hello @dave_in_ni, it's nice to see you are visiting the Community more often. When an integration is not retrieving the data from your Fitbit account the best to try is to revoke the access and reconnect both account one more time. So I suggest to give it a try to address this issue, if you need additional help take a look at this post.
You will find there too, there is a certain number of user with the same issue, so for more details I would recommend to contact MFP directly for more help.
See you around and keep me posted.
