05-29-2016 08:09
05-29-2016 08:09
Been using Power Sync to sync to Apple Health for a few weeks, worked pretty well, and it's free. Want to recommend here.
appstore.com/powersyncforfitbit
There're bunch of other paid alternatives as well, if you search for fitbit sync, they're doing pretty much the same thing. But IMO this should be a free thing.
06-13-2016
06:38
09:15
06-13-2016
06:38
09:15
Best Answer11-15-2018 14:11
11-15-2018 14:11
I used this app (POWER SYNC) and my messaging and notifications stopped. I cannot find a place to log out which is unnerving when you know your tracking details can be monitored without you being able to stop it.
Best Answer12-04-2018 13:27
12-04-2018 13:27
so does that mean you do not recommend the Power Sync app?
Best Answer12-04-2018 13:57
12-04-2018 13:57
Probably not. Unless you planned on using it for long periods of time. I wasn’t happy with the results and I wanted to delete my information from the app and I eventually figured how to not allow data transfer from my fit bit. Personally- I do not recommend it. It was annoying constantly syncing it- but if it’s important it works for that.
