04-16-2018 21:42
04-16-2018 21:42
Has anyone had problems pairing their headphones to the Versa? My Versa is not recognizing them.
Best Answer04-19-2018 07:49
04-19-2018 07:49
Hi there @ImJakeT12, awesome to see you have joined the Fitbit Community! I was reading your Fitbit Versa is not recognizing your SoundPeats headphone.
If you are having troubles, please refer to our help article: How do I connect Bluetooth audio devices to my Fitbit watch?
If the issue continues try the suggestions mentioned in this post: Bluetooth headset not pairing.
Just a heads up, since the topic of your post is not related to third party integrations, I have moved your post to our Versa board to maintain the focus of your question align with the readability of our Community..
See you later and hope this helps.
Best Answer08-03-2018 00:10
08-03-2018 00:10
Even i am having the same problem it doesn't connect to my watch....have you found any solution for this if yes please let me know
Best Answer12-21-2018 10:10
12-21-2018 10:10
I am having same problem
Best Answer12-21-2018 11:21
12-21-2018 11:21
I figured it out, what I did was while holding the button down to turn on the Soundpeats Q12 continue to hold it a few more seconds after hearing the audio prompt that its on. The led light will start to flash blue/red repeatedly indicating its in pairing mode at this time click the add audio device on the fitbit watch and it should find your headphones.
08-27-2020 16:45
08-27-2020 16:45
This solution worked a treat. Thanks!
