01-27-2014 13:33
01-27-2014 13:33
Is it possible to save data entered on Spark People to fitbit?
Best Answer01-27-2014 15:32
01-27-2014 15:32
The App gallery is here
http://www.fitbit.com/apps
Wendy | CA | Moto G6 Android
01-27-2014 15:32
01-27-2014 15:32
01-28-2014 07:08
01-28-2014 07:08
Many thanks!
I knew I had seen it somewhere.
Best Answer08-07-2014 21:10
08-07-2014 21:10
I can not get the food to come into the fitbit. Could you tell me how you do it. The only sync I see is in sparkpeople under activities. It brings the activity data over into sparkpeople but the food does not transfer to fitbit. I tried unlinking them and linking them again and the same thing.
Best Answer02-09-2017 09:21
02-09-2017 09:21
This is helpful to pull data FROM the Fitbit, into SparkPeople,
but the question is how to pull the Food Logging/calorie data logged into SparkPeople, into the Fitbit dashboard.
Have not seen this answer yet.
Best Answer02-10-2017 08:14
02-10-2017 08:14
Welcome to the Community @WillisMadden!
Food information should migrate automatically from Sparkspeople to Fitbit. It is important that food is the only information that will be transferred from Sparkspeople to Fitbit.
I hope you find this information useful! If you have any further questions, let me know.
Best Answer02-22-2017 13:36
02-22-2017 13:36
Hi,
Your note is a little old, however here's hoping.. Updated from Sparker to Fit bit. Could you please tell me how I can upload fitbit to Spark People?
Thank you,
Gail
Best Answer02-23-2017 10:53
02-23-2017 10:53
Hello @subteach55! Let me help you get those two connected.
In order to have your Sparkspeople account pass the food information on to Fitbit, follow these steps:
That should do the trick. Let me know how it goes!
Best Answer02-23-2017 13:29
02-23-2017 13:29
02-24-2017 06:47
02-24-2017 06:47
Hello there @subteach55!
Have you tried to log any food into SparksPeople and then verify if the entry shows up on Fitbit after a couple of minutes?
If possible, I'd like for you to please take a screen shot of the page where you got this from, so that I can see it myself.
Look forward to helping you find a solution to this situation.
Best Answer02-24-2017 06:55
02-24-2017 06:55
Best Answer02-26-2017 12:29
02-26-2017 12:29
Hello there @subteach55! Thanks for reaching back with that clarification.
So that I can better understand the whole situation I'd like to ask you to take another screen shot. However, this time I'd like to ask you to take the screen shot showing your Dashboard's main page. That should let me get a better understanding of what is going on and find the best way to go about this.
Look forward to your reply so that I can help you get this resolved.
Best Answer02-26-2017 16:54
02-26-2017 16:54
Best Answer01-27-2019 10:01
01-27-2019 10:01
Hi, I have the Fitbit Charge 3 and recently re-joined SparkPeople. I connect my Charge 3 via the SparkPeople app and gave permission for steps, nutrition, and weight. The data from my fitbit shows up in the SparkPeople app and on line via PC but the nuturition/food logging I put in SparkPeople is not showing up in the Fitbit app. How can I get the food and calories to syn with my Charge 3?
Best Answer01-27-2019 10:17
01-27-2019 10:17
Hello @SunsetRunner.
Thanks for sharing your experience.
In this case it is possible that it was designed to work that way. My suggestion would be to get in touch with SparkPeople directly. Given that they were the ones that created the integration they should be able to provide more details on what is going on.
Look forward to your reply.
