Spinning & Strava
ANSWERED
My first exercise session after setting up my new Sense was a spinning class.  I did choose spinning as the exercise activity on the Sense.  After the session completed, I noticed that the spinning activity was displayed on my Strava account.  The metrics shown in Strava were speed, cadence, power, calories, elapsed time, distance, moving time.  That spinning ride is the only one that has been transferred/synch'd from Fitbit.  I also was using the Stages Flight app, but I don't think the use of that app had anything to do with data showing up in Strava since I've used that app before without data being synch'd into Strava.  Any ideas?   Thank you!
1 BEST ANSWER
Accepted Solutions
Fitbit doesn't sync non-GPS activities to Strava so if the app you mentioned has been paired with your Strava account that could be the reason.
You mentioned cadence. To see cadence you need a sensor paired either with your watch (which Fitbit is unable to do) or the app. Have you used smart trainer with ANT+ sensors for cadence/speed/power? Can the SF app pair with them? If this is not the case then I don't know 🙂
2 REPLIES 2
Thank you for your reply.  I will have to contact the Stages Flight app support and see why that app only successfully and correctly relayed data into Strava.
