09-14-2017
12:45
10:24
RobertoME
09-14-2017
12:45
10:24
RobertoME
I cannot seem to control Spotify with my fitbit blaze. I have a Samsung 7 edge. I would also like to know if I can get notifications from WhatsApp on my fitbit.
Moderator Edit: Updated Subject For Clarity.
Best Answer09-16-2017 10:23
09-16-2017 10:23
Hello @Chucklevis1on, good to see you have joined the Fitbit Community! About the music control make sure your tracker has enable this option.
If you have a compatible Android or Windows 10 mobile device:
If this is not working and you were previously able to control music but now see "Not connected" or "Connecting..." on your Blaze, test whether you're able to control music after trying each of these tips:
Blaze occasionally doesn't appear right away on your list of Bluetooth devices. If you aren't seeing your Blaze, try these troubleshooting steps:
To enable notification if you are on Android yes you can use this feature. Follow the steps from this post for more details.
Hope this help and let me know if you have additional questions.
