09-17-2015 01:38
09-17-2015 01:38
I tracked a run on strava and for the start of it I used the stopwatch on fitbit charge HR.
The strava data has not loaded to fitbit like it has before.
Do i need to delete the workout recorded by the charge hr for strava to upload?
Thanks
Best Answer09-17-2015 11:58 - edited 09-17-2015 12:00
Hi @Mbf
Have moved your post from the Charge HR to the Third-Party Integrations section to increase the chance of getting a solution.
Your post will get more attention here.
Wishing a wonderful evening / night.
Best Answer09-17-2015 14:17
09-17-2015 14:17
Best Answer09-18-2015 01:02
09-18-2015 01:02
Make sure your Fitbit and Strava accounts are linked properly together here - https://strava.fitbit.com/
Best Answer09-18-2015 01:55
09-18-2015 01:55
Thanks, I've done that.
It was ok for the 1st ride but nothing the other day.
Not sure of the process to it for example, do I use both phone apps, which do I start 1st etc.
Its mainly for the bike, where the fitbit falls short but if I can get run data into fitbit as well then great.
