12-20-2020 03:06
12-20-2020 03:06
I'm using Charge 4. Using it for swimming at the pool and unfortunately
1. I can't rely on it to help remind me of my laps
2. Once uploaded, the time is rounded to the nearest minutes. Can i view it in mm:ss?
Best Answer10-04-2022 11:28
10-04-2022 11:28
Hi there @Djenggo. Welcome to Community Forums.
I appreciate you share your experience with the Community. I'd recommend you check this article, How do I track my swims with my Fitbit device? so you can track accurately your swims.
Regarding the calculation of time, you can always divide the total time within 60 secs and get a result on minutes and seconds from your laps.
Hope this helps.
Best Answer10-04-2022 12:34
10-04-2022 12:34
Hey @LucioFitbit ,
I followed the link provided by you and stumbled in the table under the section What are my options for swim tracking with my Fitbit device?
Can you help me to understand the difference between the first 2 columns because I'm confused.
Thanks
Best Answer10-05-2022 11:50
10-05-2022 11:50
Hi there @Dopovo, it's good to have you back.
Thanks for the comments and information provided. I would like to share this with you:
It must be taken into account that this information will mostly be in the app but in most devices it will not be seen on the watch during the exercise.
Hope this helps.
Best Answer10-05-2022 16:48 - edited 10-05-2022 16:49
Thanks a lot @LucioFitbit for clarification however I think the table has quite many mistakes.
In particular the trackers Charge 4 (as evident by the post by @Djenggo that you likely didn't read carefully), Charge 5, Inspire HR, Inspire 2, Inspire 3 and Luxe can no track swim lenghts in the exercise app hence the checkamrk should on the 3rd column rather than the middle one.
I'm surprised about the many mistakes lately present in the Fitbit documentation.
Best Answer10-17-2022 14:13
10-17-2022 14:13
Hey @LucioFitbit any follow up on my comment? Thanks
