05-02-2019 04:20
05-02-2019 04:20
Hi all, need your help & advice.
Currently I am using Fitbit charge 2. Previously, I will sync my Fitbit with RunKeeper. Everytime I go for a run, I will turn on the following on my phone:-
1. Bluetooth
2. GPS
3. Runkeeper
I now change to using Strava and I have setup Fitbit to sync with Strave
Do I need to turn on Strave everytime I go for a run? Because if I do not, Fitbit doesn't seem to be able to sync the info to Strava.
I'm confuse
Best Answer05-03-2019 12:03
05-03-2019 12:03
Hello @SooKH of your Stabs and Fitbit accounts are connected then you can use the GPS connected running option on the Charge 2.
After your Charge 2 syncs with your Fitbit account the data will be sent to Strava.
