02-19-2022
06:00
11:10
EdsonFitbit
02-19-2022
06:00
11:10
EdsonFitbit
I have the calm app and use it for meditation and mindfulness. It would be a great feature if the mindful minutes spent in the calm app would sync to my Fitbit account.
Best Answer02-21-2022 11:10 - edited 02-22-2022 17:02
Welcome to the Fitbit Community, @Mike6436.
Thank you for your suggestion.
Currently, there is no integration between Fitbit and Calm. If you have Fitbit Premium you can have access to some Calm sessions from the Fitbit app. For more information about this topic, please visit our blog.
You are welcome to vote this suggestion about integrating Fitbit with Calm.
Have a nice day.
02-22-2022 01:51
02-22-2022 01:51
@EdsonFitbit Are you sure about it? I don't see anything related to Fitbit in the settings of Calm app.
Best Answer02-22-2022 16:58
02-22-2022 16:58
Thanks for visiting the Fitbit Community, @SunsetRunner.
I was informed by my team that at the moment there is an agreement between Fitbit and Calm which allows to access some Calm sessions from the Fitbit app. You should have access to 30 pieces of Calm but no information will be synced between your apps. Sorry for the misunderstanding, I just edited my post above to avoid any confusion.
There is a suggestion called "Sync with 3rd party meditation apps". You are welcome to vote it and if there is any update, it should be communicated as soon as possible.
Have a nice day.
Best Answer02-23-2022 08:24
02-23-2022 08:24
I think they’re referencing the calm sessions that you can do as part of Fitbit premium. They’re sessions separate from the Calm app that you can do as part of the mindful minutes element of the dashboard.
