I have followed all of the other suggestions but I must be missing something still. I want the exercises I log on the Fitbit to sync over to MFP. I've got other exercies from Map My Fitness syncing over just fine to MFP. The calorie adjustments are not working for me for some reason. It doesn't show up on MFP until I make another exercise entry and then it shows a negative balance for the day which is not my goal.
I had purchased a Garmin Vivosmart HR+ and it synced just fine. But, the display was hard to see so I wanted to try the Fitbit. Do I have to manually add my exercise log from Fitbit to MFP? I sure hope that is not the answer.
Any help/direction would be greatly appreciated.
@mstephens93 Fitbit activity logs do not sync over to MFP. To see what syncs between the two, check this post. You should really only be logging activities in one place, so if you want all your activities to show up in MFP, then you shouldn't be logging activities in Fitbit.
Best AnswerThanks for the info. So, can you let me know what the best process would be to use the Fitbit activities and keep track of my calories? I did adjust the Fitbit side to match the goal calories on MFP and my food entries on MFP are syncing over to Fitbit.
