Hi
I would like to buy a withings body+ smart scale to track my weight. But instead of the withings/healthmate I would like to use the tracked data in the fitbit dashboard. That is, because for step tracking etc. I would like to use the fitbit charge 4. I would like to have everything in one place ( in the fitbit app/dashboard).
As far as I could find out it is possible to sync weight data from whitings/healthmate to fitbit in general. But I couldn’t find out which data is synced exactly.
So I would like to ask 2 questions.
Thanks
Best AnswerJust got a Withings Body + and despite supposedly linking it to fitbit, nothing is getting imported at all automatically. It will import a manual entry I tried (which I entered on the health mate app but none of my daily weighings on the body + are appearing. Not impressed so far.
Hey thank you for your reply.
Thats sad...
May i ask you how you synced the body+/health mate app with the fitbit app?
Did you use the connection assistant? (https://www.fitbit.com/weight/withings)
Yes I did , stikl doesn't sync. Had enough of it, already arranged to return it to Amazon and will get an Aria 2.
