@SunsetRunner Thanks for moving the post!
@Abz12 A warm welcome to the Community! You mentioned that it has recorded MyFitnessPal calories so I believe you already linked both accounts by doing this linking procedure posted by @SteveH. Also, please make sure that you're seeing the steps and sleep data in the "check-in" section of MFP.
Hope this helps.
@Abz12 Thank you for the details! In this case, I would recommend to unlink and relink both accounts to see if the steps start syncing again.
If you're still not getting the correct information in your Dashboard, contact MyFitnessPal directly. Sometimes they're syncing issues and they post it in their site.
Hope this helps.
