Welcome on board @briangrafjr, it's nice to see you here! So based on the rule, MMR doesn't send data but only receives information from your Fitbit account. So it's okay to track your exercise in MMR.
Nonetheless this is the tricky part, you cannot use your Ionic to track the same exercise, due to the same rule. Your Fitbit will send information to your MapMyRun account for the same exercise causing duplicate numbers, at least for steps, distance and calories; which is the information that your Fitbit account share with MMR. For more details review this post: Third Party Apps - Informational Post.
So the straight answer would be to choose where you want to track your exercise, since it is not possible to use both apps for the same exercise based on the conditions that rule this integration.
I've moved your post to the Third-Party Integrations board as there are more chances to get related replies here.
Hope this helps, let me know if there's anything else I may assist you with.
