10-04-2018
17:53
12:21
SelmaFitbit
10-04-2018
17:53
12:21
SelmaFitbit
My fit it isn't recording my activity to my weight watchers app
Moderator edit: Clarified subject and labels
Welcome to the Forums @Sirilee2.
Thanks for trying to update the apps before posting in here.
Let's try to disconnect the two apps and then connect them once again. That should help so that the information being to sync to WW. Please try that and keep me posted on how it goes.
Let me know if there are any further questions.
Best AnswerThanks for ur response its syncing with the weight wTchers app but on the activity menu it says fitbit 0 it doesnt show how many steps I have done but it does on the my journey page of weight wTchers app if that helps
Hello @Sirilee2.
Thanks for that information.
I'd recommend that you try to get in touch with WeightWatchers directly. Given that these integrations are developed by the third parties, they should be able take a closer look at what is going on and help you get it resolved.
Let me know if you have any further questions.
Hello @Sirilee2.
Thanks for the update.
Hopefully they will be able to look into it and let you know exactly what is going on. If they do, please share it with us in here.
Be sure to visit our Discussion boards if you have the time. Lots of topics to talk about with other users.
