08-21-2020
04:58
16:23
SilviaFitbit
08-21-2020
04:58
16:23
SilviaFitbit
Hi, I had NOOM integrating with FitBit, (pedometer only because it doesn't seem to integrate with anything else like exercise, water consumption, food diary, wiegh in... Or anything else). When FitBit didn't record my walk this morning because I accidentally started an upgrade, I thought I could just update the number of steps in NOOM and it'd integrate (because FitBit Inpsire HR doesn't have an update steps option). When it didn't work I thought if I unlinked them, uninstaller NOOM, it might let me update the steps in NOOM, which didn't work! Now my NOOM pedometer won't count steps at all nor integrate with FitBit. It seems like FitBit has seized its ability to do so (because the fine print and the bottom of the page in NOOM says its recording the steps from FitBit, but I. My attempt to unlink, I'd revoked NOOM but now I cannot get it to link again because there is no longwe functionality in FitBit or NOOM for me to do so). Could you please reset my FitBit to allow linking with NOOM?
@BernadetteJoy A warm welcome to the Fitbit Community. Thanks for getting in touch about this.
I appreciate the troubleshooting tried prior to posting. Please try the following instructions to connect Fitbit to NOOM:
As a side note, there's no need to reset your Fitbit because this integration will work between accounts.
I'll be around if you have any additional questions.
Best AnswerHello,
I have done the same as the OP and now the apps will not link together. I have followed the previously mentioned steps but it does not link the 2 apps. Is there something else that can be done?
I have this same issue. followed the instructions but my steps will not sync. Did you get a resolutions to this problem?
TIA
No luck in getting the issue resolved. Noom says it is a fitbit issue, but I don't think that is true.
