Hi,
I am trying to figure out how digifit and fitbit work together. Which one has precedence over the various modes, steps, calories, activity? I believe steps belong to Fitbit and calories and activity would be digifit. After a almost 4mile hike up some hills and some flat. Fitbit sync says I did about 37min actvity and then when I sync digifit (which is taking longer than normal when I first started using this setup) the Activity was only 1min and took away the 37min does this seem correct? That variance is a pretty big difference? Also if you have heart rate monitor failure what happens then how does it get recorded from fitbit or digifit, because this happens on a daily basis sometimes, I use Polar wearlink bluetooth classic, older smart phone.
Any insight would be appreciated
It's great to see new faces here in the Community @azubes! Linking your Fitbit and Digifit accounts, and your workouts are "automagically" posted to your Fitbit account and Fitbit activity to My.Digifit.com.
Did you try uninstalling and reinstalling Digifit with Fitbit?
