Versa 3 not syncing with Strava
ANSWERED
I have had no success syncing since early Jan from Fitbit to Strava, each one saying its the other fault. Fitbit says my watch is syncing, and Strava issue, while Strava says it sits with Fitbit? I have reset and reloaded both apps multiple times. I feel that it may be to do with the Fitbit going to Google, but not sure. It is ridiculous manually uploading activity when it synced previously no issue. Any one else?
Moderator Edit: Clarified subject and updated label
1 BEST ANSWER
Accepted Solutions
Hi Everyone!
I'm glad to inform you that we've made some updates to the Strava integration that should address issues with workouts syncing between the apps.
Additional Troubleshooting Steps (if needed): Make sure your Fitbit and Strava accounts are connected, please check that you see Fitbit listed under "Manage apps and devices" in Strava settings on the Strava app and ensure that Strava is also listed in the Fitbit app.
Fitbit App: Using a Google Account:
  • In the Fitbit App, tap on your Profile picture (top right), Fitbit Settings, Manage access to account, Manage connected apps.
Fitbit App: Using a Fitbit Account:
  • In the Fitbit App, tap on the Gear (top right), Fitbit Settings, Manage access to account, Manage connected apps.
We always appreciate your feedback, thank you for your patience.
4 REPLIES 4
Hi there, @LeanneE18. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 3 is not syncing with Strava. I understand your concern, we're here to help you!
As you mentioned, I've seen you contacted our Support Team after posting here and they've already assisted you. Nevertheless, please note that your case was forwarded to our higher tier of support for further checking. Someone will be in contact with you soon as they have the resolution for this issue. Stay tuned to your inbox!
Thanks in advance!
I am the exact same. Since christmas (roughly) my firbit isn't syncing with strava. Strava have blamed fitbit and I've had no answers from Fitbit yet.
did this ever get resolved? Fitbit stopped syncing to strava. I also find it silly to manually upload files since it was already working previously.
Revoking access and adding back in didn't do anything either. Fitbit also was having trouble connecting with my pixel watch 3 after logging out an logging back in.
Would think that the integration between the two would be seen less since they are made to work with each other.
Hi Everyone!
