01-22-2021
00:09
03:43
01-22-2021
00:09
03:43
My versa 3 has suddenly decided to start recording a massive amount of calories . I woke op this morn ok my and apparently I've already burned 2200 calories overnight! Usually I'd be lucky to burn 400 ! It all started when i.paired steps to my fitness pal . Does anyone have any ideas please? Thank You
Best Answer01-23-2021 03:42 - edited 01-10-2024 11:57
Hi there @Ajamtart, welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 3.
Note sometimes if you're not using your watch but you have a third party app associated to your Fitbit account, is possible that the activities logged in the third party account are syncing AZM through your Fitbit account (it will definitely add calories too), even when is not showing steps.
To explain this, I have tested it on my dashboard and this is the final result: I logged an activity using MyFitnessPal and today I haven't synced any steps from my Fitbit device. I should not have active minutes (for this I used my Charge 2 which calculates active minutes not AZM), and as you can see on the screenshot, I have the same amount of active minutes and calories that the activity I logged on MFP.
Can you check this?
I've moved your post to Third-Party Integrations for organization purposes.
Can you check this?
