09-09-2017 11:59
09-09-2017 11:59
I use a Matrix Ascent trainer which connects to the ViaFit website. I have linked that account to the FitBit website account so my training sessions log. The problem I am having is my Charge 2 is logging the same event with different stats. I want to use the Vitafit info so do I have to delete the entry my FitBit logs to correctly count my calorie burn?
Best Answer09-11-2017 06:37
09-11-2017 06:37
Hi there @CDNGrant, it's nice to see you have joined the Fitbit Community! Yes, you are correct, in this case as you mentioned, your tracker is recording the same information as Matrix Ascent is syncing with ViaFit and by consequence due to the integration is duplicating your calories in your Fitbit account.
The easy way is to delete the duplicate session you are seeing on your exercise history.
The other alternative I can think out of this, is that your tracker probably is automatically recording your exercise, which means is using the SmartTrack feature. You can go to your Fitbit app and go to your exercise tile, right in the upper corner you'll see a Gear Icon that will allow the access to your exercise goals, here you can disable the session your tracker is recording automatically.
Hope this helps and let me know if you have another question.
09-11-2017 06:37
Best Answer09-11-2017 09:57
09-11-2017 09:57
Thank you for the reply and the info, I appreciate your time. I will try your solution out and get back to you if it doesn't work.
Thanks again
Grant
