08-14-2014
02:55
12:52
AngelaMa
08-14-2014
02:55
12:52
AngelaMa
Hi, I am a member of weight watchers in the UK. I received a booklet from them as part of my membership and inside it I found exciting news that you can sync your paid weight watchers account with your fitbit! So instead of calories, it counts in ww pro points. This was meant to go live in January but has failed to do so. Can you tell me anymore information about when its likely to happen, if ever? Thank you
Best Answer08-14-2014 13:53
08-14-2014 13:53
Any syncing ability was developed by Weightwachers using the Fitbit API. You will need to discuss with them.
Best Answer09-11-2014 08:41
09-11-2014 08:41
Weight Watchers announced that it went live today. But I still can't figure out how to do it on my android. If you figure it out, please share!! 🙂
Best Answer09-11-2014 09:41
09-11-2014 09:41
Best Answer09-12-2014 07:02
09-12-2014 07:02
I would also be interested to sync my fitbit that arrived this morning. That is why I brought it as joined Weight Watchers two weeks ago. I cannot work it out so living in hopes .......
Best Answer09-12-2014 11:16
09-12-2014 11:16
The Fitbit must be synced thru your eTools account on the computer. It can not be done thru the app
Best Answer09-12-2014 11:42
09-12-2014 11:42
Best Answer09-12-2014 13:04
09-12-2014 13:04
It is only in the US for now. I didn't notice that the post said UK. Sorry about that.
Best Answer09-23-2014 09:11
09-23-2014 09:11
does any one know if its posiable to sync wheight watchers and fit bit in the UK yet?
