09-21-2017 07:28
09-21-2017 07:28
How do I sync my Weight Watchers calories with my Fitbit so I don't have to enter everything twice?
Best Answer09-21-2017 07:46
09-21-2017 07:46
Hi, @HarrogateBird! There should be an option in your ww app to link to other apps or accounts, you can just log in there with your Fitbit credentials.
MakMak | Community Council
Best Answer09-21-2017 07:55
09-21-2017 07:55
Best Answer09-21-2017 08:13
09-21-2017 08:13
I did a little searching on the Fitbit forums and it looks like as of last year at least they don't sync food. I've noticed that once an app links up to Fitbit, they don't usually update what they are doing. But if this is something you want to push for, you would have to do it on the ww side. Fitbit doesn't control how 3rd party apps connect.
