02-14-2022
16:30
13:31
EdsonFitbit
02-14-2022
16:30
13:31
EdsonFitbit
I’ve noticed that as of 2/7 my weight has not been syncing with MyFitnessPal. When I look at the MyFitnessPal app, it is getting my steps and calories from the Fitbit app when I sync.
I have a Sense. I have the latest updates for my Sense and the iOS app.
thanks,
Bob
Thanks for your question, @rshotok.
If you are having difficulties to sync the Withings scale, which was the problem mentioned by @KamokuRyuu, you can link it directly to Fitbit by following the instructions here.
As an alternative, you can sync Withings with Fitbit through IFTTT. For instructions, please visit this site.
See you around.
Thank you for visiting the Fitbit Community, @rshotok.
I'm sorry to hear about the difficulties you experienced. Thank you for the information provided.
In this case, I would recommend revoking the access between your Fitbit and MyFitnessPal apps and connect them once again. For instructions, please visit this article.
Hope this helps.
Best AnswerMine also hasn't been syncing since 2/7/2022. I tried revoking access and now I can't figure out how to add Myfitnesspal back into my allowed apps. MFP is pulling data from fitbit but not the other way around. The fact that multiple people had this issue starting the same day makes me think it's a problem on fitbit's side.
Welcome to the Fitbit Community, @KamokuRyuu.
@rshotok @KamokuRyuu If you haven't done so, please follow the troubleshooting steps in this page.
@KamokuRyuu In the same link shared above you'll find instructions to add MyFitnessPal back to your allowed apps.
See you around.
Best AnswerThanks. I ended up googling and finding a link that would let me connect my withings scale directly to fitbit rather than trying to go through Myfitnesspal (which was also pulling from withings scale). That seemed to work. I did disconnect MFP and Fitbit and reconnect them as well. What I didn't mention in my first post was that fitbit was syncing other MFP data (food logs), but it wasn't pulling weight data. So that's why I tried searching for how to connect the scale directly.
Thanks for your response, @KamokuRyuu.
I'm glad to hear that you've found a solution to sync your data.
On another note, you are welcome to visit the Health & Wellness board to talk with other members about health and fitness.
Have a nice day.
Best AnswerHi, can you share the link you found? No matter how many times I remove/add the relationship to MFP, I cannot get the weight to sync.
See you around.
Thanks for the update, @rshotok.
I'm glad to hear that you've been able to connect your Withings scale directly with Fitbit.
See you around.
