Where can I see the interaction between Endomondo and Fitbit?
ANSWERED
how and were can i see the interaction between endomondo and fitbit ??
1 BEST ANSWER
Accepted Solutions
@SunsetRunner wrote:
I already linked them, but cant see the information any were ??? What do I
have to look for in the dashboard ??
The activity from Endomondo should show up here if it was today: https://www.fitbit.com/activities
If it was from an earlier day, click on the "week" tab.
14 REPLIES 14
You need to link them
The App gallery is here http://www.fitbit.com/apps
When Endmondo is synced with fitbit it will bring the record over
Community Council Member
Wendy | CA | Moto G6 Android
Ok I tested it this morning. I maded sure I was linked here.  When I got back I checked it it did not bring it across.
So I went to Endomondo and Click on Settings then go to connect. Scroll down and link fitbit there.
And make sure Auto post has a check mark.
Pretty sure this will do it. But i cant test right now. Phone is charging. Its one of the reasons I dont use it anymore. It drains my phone to much
@SunsetRunner  I sent in a support ticket as after linking it an Endomondo as well it still didnt bring it over after a sync.
I will let you know!
From support
Hello Wendy,
We're sorry to hear that your activities are not being carried over from your Endomondo and Fitbit accounts.
Upon checking, we verified that your two accounts were linked on November 16, 2011.
As a workaround, we suggest that you re-link the two accounts by doing the following:
1. Log into your Fitbit account.
2. Click the gear icon on the upper right hand of the screen.
3. Select "Settings".
4. Go to "Applications".
5. Scroll to Endomondo and click "Revoke Access".
Then, to re-link your two accounts please go to www.fitbit.com/apps/endomondo and click “get started”. Once connected you will be able to view the activities that you log in your Endomondo account under your manually logged activities in your Fitbit account.
On your Endomondo account, you should already see the steps and distance tracked by your Fitbit in your workout tab.
We hope this helps. Let us know if this does not help so we can assist further.
Please try this as I will be as well for tomorrow.
Let me know
Hi Wendy
Thx for the reply 🙂 I can now see that my endomondo app picks up the walking information tracked by the fitbit. This information I can see in endomondo.
But does it also work the other way arround ?? Does fitbit pick up from endomono and use that information ???
Best regards
Kenneth Jensen
Happy fitbit user 🙂
Hi,
I also see that my Endomondo app picks up the walking information tracked by the Fitbit when I login to Endomondo.
But the other way round there is no Endomondo tracking that shows up in Fitbit dashboard. My 2 account are connected and I have tried to reconnect.
How does I get it to work that Fitbit picks up data from Endomono and use that information?
I bought the Fitbit Flex in expectation of this functionality, so I hope anyone can help
Best regards
Petra
If you track a workout (say biking) in Endomondo and have your accounts connected it will show up separately in your activity log, not the dashboard. After logging an Endomondo workout and giving it some time to sync, look here under activity history: https://www.fitbit.com/activities
Sorry, I meant the activity log at https://www.fitbit.com/activities. No, the workouts from Endomondo don't show there either 😞
Petra
Hi Kenneth,
Maybe your problem is the same as I had. My solution was to make a new Endomondo account with the same email as the Fitbit account. Previous the two where different.
Now it I also get my workouts from Endomondo into my Fitbit activity list 🙂
Best regards Petra
I linked my endomondo account, but now my fitbit steps show up on my endomondo training log, but not the runs that I tracked with Endomondo. I don't want it to work this way round so I've unlinked my account until I can be sure I won't lose my run info. I would like my runs to show on my fitbit log without having to manually log them, which isn't happening, but I'm more upset that I've lost the info on 2 runs I did.
@Kay1509 Syncing is two way with Endomondo. My Fitbit steps appear on my Endomondo training log and my bike rides tracked with Endomondo appear in my activity log on Fitbit. Did you have the box "Auto-Post new workouts to Fitbit checked at Endomondo? See this page for more info.
I can see my workouts in Endomondo appearing in fitbit but they show 0 steps taken. is there a way to show the steps taken during workout against endomondo activities in fitbit and endomondo both?
