03-30-2019 19:41 - edited 03-30-2019 19:56
I’ve tried connecting my Fitbit and MyFitnessPal and it keeps coming up this message. I have revoked access several times and tried again, I have also had redownloded the apps. What is going on and why won’t it connect
Best Answer03-31-2019 05:21
03-31-2019 05:21
Hello @hanna_hess it is telling you that yesterday you connected a MFP account to tout Fitbit account.
What makes you say that the 2 accounts are not connected?
Whew you loved into the correct MFP account while connecting the two accounts?
03-31-2019 09:53
03-31-2019 09:53
On myfitnesspal in the apps it says there are no apps connected. And steps etc is not showing up from my Fitbit on myfitnesspal.
Best Answer04-02-2019 08:50
04-02-2019 08:50
Hello @hanna_hess. Thanks for being around @Rich_Laue.
I apologize for the delay in my response. @hanna_hess Thanks for sharing those screenshots and details on what is happening with your MyFitnessPal and Fitbit accounts.
In this case I'd recommend that we try disconnecting the two apps and then connecting them again. You can click here to find the specific steps on how to do it. This should help so that it shows correctly on both ends.
Keep me posted on how it goes or if you have any further questions.
Best Answer06-05-2019 19:32
06-05-2019 19:32
You might want to subscribe to the main thread at
For the latest updates from Fitbit on this https://community.fitbit.com/t5/Third-Party-Integrations/MyFitnessPal-Syncing-Issues-06-03-19/td-p/3...
