When I manually logged in an activity on my fitbit dashboard it claimed calories burned at 280, however mfp has estimated the same activity as 432 calories burned. Why is there such a huge difference and which to believe? And no I have not manually double logged this activity, I was just curious to see if both programs would match calculated calories burned.
@telergirl Welcome to Fitbit Community! Make sure that you have the same profile settings on both accounts (age, gender, weight and height).
Also, MyFitnessPal has changed the way they handle the Fitbit adjustment. This change is intended to give users a more accurate representation of what they should eat. You can read more here: Total daily calorie partners. Let me know if you have another question.
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
@slysam This is an excellent advice! I'm definitely going to refer every user with a similar inquiry to your detailed observation. Thanks!
